Saltar al contenido principal
TRS-80 Color Computer Power Cord Replacement
Qué necesitas
  1. TRS-80 Color Computer Power Cord Replacement, Outside Casing: paso 1, imagen 1 de 1
    • Flip the computer over.
    • Remove the two 24.1mm Phillips screws near the front of the case.
    • Remove the five 33.0 mm Phillips screws towards the back of the case.
  2. TRS-80 Color Computer Power Cord Replacement: paso 2, imagen 1 de 2 TRS-80 Color Computer Power Cord Replacement: paso 2, imagen 2 de 2
    • Carefully flip the computer right side up.
    • Lift off the top half of the case.
  3. TRS-80 Color Computer Power Cord Replacement, Keyboard: paso 3, imagen 1 de 2 TRS-80 Color Computer Power Cord Replacement, Keyboard: paso 3, imagen 2 de 2
    • Near the motherboard, gently pull the keyboard ribbon cable until it becomes free.
    • Lift the keyboard out of the case.
  4. TRS-80 Color Computer Power Cord Replacement, Motherboard: paso 4, imagen 1 de 3 TRS-80 Color Computer Power Cord Replacement, Motherboard: paso 4, imagen 2 de 3 TRS-80 Color Computer Power Cord Replacement, Motherboard: paso 4, imagen 3 de 3
    • Remove the nine 15.24 mm Phillips screws securing the motherboard in place.
    • When removing the spring door, make sure to keep the door closed.
  5. TRS-80 Color Computer Power Cord Replacement: paso 5, imagen 1 de 3 TRS-80 Color Computer Power Cord Replacement: paso 5, imagen 2 de 3 TRS-80 Color Computer Power Cord Replacement: paso 5, imagen 3 de 3
    • Remove the 5 jumper cables from the motherboard.
    • Once the jumper cables lift the motherboard up gently; it should lift out easily.
  6. TRS-80 Color Computer Power Cord Replacement, Power Cord: paso 6, imagen 1 de 2 TRS-80 Color Computer Power Cord Replacement, Power Cord: paso 6, imagen 2 de 2
    • Remove the two 1.6 inch screws securing the transformer.
  7. TRS-80 Color Computer Power Cord Replacement: paso 7, imagen 1 de 1
    • Remove the power cord's three leads from the transformer.
    • Note the orientation and color of the three leads. Make sure to replace these exactely as they were.
  8. TRS-80 Color Computer Power Cord Replacement: paso 8, imagen 1 de 2 TRS-80 Color Computer Power Cord Replacement: paso 8, imagen 2 de 2
    • Using needle-nose pliers, pinch the tabs of the grommet holding the power cord to the case and push the grommet out.
    • Remove the entire length of cord from the case and replace with a new one.
Conclusión
5 personas más completaron esta guía.
Equipo
Cal Poly, Team 11-24, Maness Winter 2011 Miembro de Cal Poly, Team 11-24, Maness Winter 2011
CPSU-MANESS-W11S11G24
4 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 14
Ultimos 30 días: 17
Todo El Tiempo: 2,299
