Saltar al contenido principal
TRS-80 Color Computer Motherboard Replacement
Qué necesitas
  1. TRS-80 Color Computer Motherboard Replacement, Outside Casing: paso 1, imagen 1 de 1
    • Flip the computer over.
    • Remove the two 24.1mm Phillips screws near the front of the case.
    • Remove the five 33.0 mm Phillips screws towards the back of the case.
  2. TRS-80 Color Computer Motherboard Replacement: paso 2, imagen 1 de 2 TRS-80 Color Computer Motherboard Replacement: paso 2, imagen 2 de 2
    • Carefully flip the computer right side up.
    • Lift off the top half of the case.
  3. TRS-80 Color Computer Motherboard Replacement, Keyboard: paso 3, imagen 1 de 2 TRS-80 Color Computer Motherboard Replacement, Keyboard: paso 3, imagen 2 de 2
    • Near the motherboard, gently pull the keyboard ribbon cable until it becomes free.
    • Lift the keyboard out of the case.
  4. TRS-80 Color Computer Motherboard Replacement, Motherboard: paso 4, imagen 1 de 3 TRS-80 Color Computer Motherboard Replacement, Motherboard: paso 4, imagen 2 de 3 TRS-80 Color Computer Motherboard Replacement, Motherboard: paso 4, imagen 3 de 3
    • Remove the nine 15.24 mm Phillips screws securing the motherboard in place.
    • When removing the spring door, make sure to keep the door closed.
  5. TRS-80 Color Computer Motherboard Replacement: paso 5, imagen 1 de 3 TRS-80 Color Computer Motherboard Replacement: paso 5, imagen 2 de 3 TRS-80 Color Computer Motherboard Replacement: paso 5, imagen 3 de 3
    • Remove the 5 jumper cables from the motherboard.
    • Once the jumper cables lift the motherboard up gently; it should lift out easily.
Conclusión
5 personas más completaron esta guía.
Andrew
Miembro Desde 01/23/11
530 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 11-24, Maness Winter 2011 Miembro de Cal Poly, Team 11-24, Maness Winter 2011
CPSU-MANESS-W11S11G24
Miembros de 4
10 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 14
Todo El Tiempo: 4,269
