Saltar al contenido principal
TI-84 Plus Silver Edition Faceplate Replacement
  1. TI-84 Plus Silver Edition Faceplate Replacement, Faceplate: paso 1, imagen 1 de 1
    • Insert your index finger in the open slot below the keys.
    • Be careful to not bend the plate too much because it is very thin and might break.
    • Apply a firm upward force until the bottom two tabs located near the bottom of the plate come off.
  2. TI-84 Plus Silver Edition Faceplate Replacement: paso 2, imagen 1 de 1
    • Grab the face plate on each side near the middle and apply a gentle upward force on each side until the middle tabs come off.
    • A tab is located in the center of the face plate. If it is still attached, then continue to apply a gentle upward force until the center tab comes off.
    • Lift the face plate upward until the top three tabs come off and the face plate is completely detached.
Conclusión
6 personas más completaron esta guía.
Agustin
Miembro Desde 10/20/13
1,028 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 11-34, Amido Fall 2013 Miembro de Cal Poly, Team 11-34, Amido Fall 2013
CPSU-AMIDO-F13S11G34
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 22
Todo El Tiempo: 10,277
