Saltar al contenido principal
TI-84 Plus Silver Edition Backup Battery Replacement
Qué necesitas
  1. TI-84 Plus Silver Edition Backup Battery Replacement, Main Battery: paso 1, imagen 1 de 3 TI-84 Plus Silver Edition Backup Battery Replacement, Main Battery: paso 1, imagen 2 de 3 TI-84 Plus Silver Edition Backup Battery Replacement, Main Battery: paso 1, imagen 3 de 3
    • Push firmly down on the tab located on the back of the calculator near the center.
    • Pull the tab up, lifting it off of the calculator and exposing the batteries.
  2. TI-84 Plus Silver Edition Backup Battery Replacement: paso 2, imagen 1 de 1
    • Removing the AAAs and the back up battery will clear the calculator's memory. Make sure you have backed up any important data prior to performing this step.
    • Push the positive (+) side of the batteries to remove them
  3. TI-84 Plus Silver Edition Backup Battery Replacement, Backup Battery: paso 3, imagen 1 de 1
    • Using the Phillips #00 Screwdriver, unscrew the 15 mm screw holding the backup battery cover, located above the main battery area.
  4. TI-84 Plus Silver Edition Backup Battery Replacement: paso 4, imagen 1 de 1
    • Grab the plate and lift gently upward, to remove the backup battery cover.
  5. TI-84 Plus Silver Edition Backup Battery Replacement: paso 5, imagen 1 de 2 TI-84 Plus Silver Edition Backup Battery Replacement: paso 5, imagen 2 de 2
    • Wedge the small plastic opening tool under the backup battery in the gap to the left of the backup battery.
    • The backup battery is an SR44SW coin cell battery. You can also replace it with a size 357/303 or LR44 battery.
    • Push gently downward until the backup battery pops out.
Conclusión
17 personas más completaron esta guía.
Agustin
Miembro Desde 10/20/13
1,028 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 11-34, Amido Fall 2013 Miembro de Cal Poly, Team 11-34, Amido Fall 2013
CPSU-AMIDO-F13S11G34
4 Miembros
6 Guías creadas
9 comentarios
My son's TI 84 Plus C has a rechargeable battery with a little cord attached to it which is significantly different from the AAA's shown in this Guide!
annualgain - Contestar
Because it's a completely different calculator.
Ozan Munsuz -
Muy instructivo e ilustrativo que permite fácilmente la operación de cambio de bacteria.
Andres Guaty - Contestar
Do NOT replace the back up battery and the main batteries at the same time! If you do, you will lose all of the calculator’s memory.
Alexander Dombroski-21 - Contestar
Too late…….. I had about 13000 bytes of programs
Aaron Rueppel -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 7
Ultimos 7 días: 29
Ultimos 30 días: 144
Todo El Tiempo: 66,290
