Saltar al contenido principal
TI-84 Plus Disassembly
Qué necesitas
  1. TI-84 Plus Disassembly, flip: paso 1, imagen 1 de 2 TI-84 Plus Disassembly, flip: paso 1, imagen 2 de 2
    • Be sure the calculator is powered off before proceeding.
    • Take off the sliding cover, and flip your calculator to the back side.
  2. TI-84 Plus Disassembly, battery plate.: paso 2, imagen 1 de 2 TI-84 Plus Disassembly, battery plate.: paso 2, imagen 2 de 2
    • Press down on the latch, then remove the battery cover.
  3. TI-84 Plus Disassembly, take out the batteries: paso 3, imagen 1 de 2 TI-84 Plus Disassembly, take out the batteries: paso 3, imagen 2 de 2
    • Remove the batteries.
    • You can use the battery cover as a plate to keep the batteries.
  4. TI-84 Plus Disassembly, back up battery: paso 4, imagen 1 de 3 TI-84 Plus Disassembly, back up battery: paso 4, imagen 2 de 3 TI-84 Plus Disassembly, back up battery: paso 4, imagen 3 de 3
    • Removing this battery will clear your RAM, so be sure that you have made any backups of important data.
    • Use a Phillips #0 to remove the plate from the back up battery.
  5. TI-84 Plus Disassembly, backup battery: paso 5, imagen 1 de 2 TI-84 Plus Disassembly, backup battery: paso 5, imagen 2 de 2
    • remove the backup battery with either a screwdriver or the spudger.
  6. TI-84 Plus Disassembly: paso 6, imagen 1 de 1
    • you can use a t6 or tr6 take out all six marked screws
  7. TI-84 Plus Disassembly, cracking the case: paso 7, imagen 1 de 3 TI-84 Plus Disassembly, cracking the case: paso 7, imagen 2 de 3 TI-84 Plus Disassembly, cracking the case: paso 7, imagen 3 de 3
    • Use a prying tool to get a pick into the side and then move it down until its open.
Conclusión
8 personas más completaron esta guía.
Un comentario
Nice! My calculator wasn't turning on, took it apart and rebent the contacts for the batteries, works great now!
Noah Molla - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 39
Ultimos 30 días: 211
Todo El Tiempo: 8,595
