Introducción
For this guide you will remove all of the internal components in order to replace the buttons.
Qué necesitas
Remove the calculator's protective cover.
Place the calculator face down.
Use a Phillips #00 screwdriver to remove the two 7.5 mm screws holding the battery cover to the case.
Use your finger to move the battery cover to the side.
After removing the battery, use a Phillips #00 screwdriver to take out the 4.5mm screw directly to the right of the solar panel.
Lift the top edge of the solar panel with a finger and slide it away from the circuit board to disconnect it from the calculator.
Carefully pry the screen out of the calculator with a prying tool or spudger.
Pry the lower circuit board from the calculator by inserting a prying tool between the base of the calculator and the circuit board.
3 personas más completaron esta guía.
