Introducción
Buttons on any device are subject to replacement due to loose conductivity or friction that tends to occur over time. This guide will show you how to property replace the buttons on the Life on Trek A34 device.
Qué necesitas
Flip your device upside down so the battery cover is facing upwards.
Using the Torx T6 screwdriver, remove all seven 6 mm Torx screws that are located along the perimeter of the battery cover.
Turn over the device so the bottom is facing up. Remove the screws of the battery cover using the iFixit TR7 screwdriver.
Remove the battery cover by pulling up where the screws should go.
Use a TR7 screwdriver to remove the screws from the battery cover located on the underside of the device.
Remove the battery cover.
Once the soldering iron is heated, carefully place the iron onto the connection point of the button.
With a steady hand, hold the soldering iron in place until the metal is slightly melted.
