Saltar al contenido principal
TDK Life on Record Trek Max A34 Battery Replacement
Qué necesitas
  1. TDK Life on Record Trek Max A34 Battery  Replacement, Battery: paso 1, imagen 1 de 2 TDK Life on Record Trek Max A34 Battery  Replacement, Battery: paso 1, imagen 2 de 2
    • Flip your device upside down so the battery cover is facing upwards.
    • Using the Torx T6 screwdriver, remove all seven 6 mm Torx screws that are located along the perimeter of the battery cover.
  2. TDK Life on Record Trek Max A34 Battery  Replacement: paso 2, imagen 1 de 2 TDK Life on Record Trek Max A34 Battery  Replacement: paso 2, imagen 2 de 2
    • Use the metal spudger prying tool to gently pry off the battery cover.
    • The battery should now be exposed.
  3. TDK Life on Record Trek Max A34 Battery  Replacement: paso 3, imagen 1 de 3 TDK Life on Record Trek Max A34 Battery  Replacement: paso 3, imagen 2 de 3 TDK Life on Record Trek Max A34 Battery  Replacement: paso 3, imagen 3 de 3
    • Starting from where the wires are connected, gently pull the battery out of the device.
  4. TDK Life on Record Trek Max A34 Battery  Replacement: paso 4, imagen 1 de 2 TDK Life on Record Trek Max A34 Battery  Replacement: paso 4, imagen 2 de 2
    • Unplug the battery from the device by detaching the wires at the white connection box.
    • Detaching the wires may require some force.
    • Be careful not to rip the wires out of the device or the battery.
  5. TDK Life on Record Trek Max A34 Battery  Replacement: paso 5, imagen 1 de 1
    • The battery is now separated from the device and may be replaced with a new battery.
Conclusión
8 personas más completaron esta guía.
Kayla
Miembro Desde 09/28/15
315 Reputación
1 Guía escrita
Equipo
Texas Tech, Team 19-3, Rauch Fall 2015 Miembro de Texas Tech, Team 19-3, Rauch Fall 2015
TTU-RAUCH-F15S19G3
4 Miembros
1 Guía escrita
2 comentarios
This post is incorrect on the size of the Torx driver! I literally just got done replacing an A34 battery and the T-7 is too large! A T-6 driver is required!
John Johnston - Contestar
my problem of my trek max unit
everytime recharge my trek max is hot.
Wilfredo Natividad - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 10
Ultimos 30 días: 50
Todo El Tiempo: 11,343
