Saltar al contenido principal
TDK Life on Record Trek 360 Battery Replacement
Qué necesitas
  1. TDK Life on Record Trek 360 Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Turn the TDK Life on Record Trek 360 on its side as shown and remove the four 8 mm screws holding the battery cover in place with the T-5 torx screw bit.
    • Before beginning this guide, be sure that the battery is completely drained of charge. This prevents electrical injury.
  2. TDK Life on Record Trek 360 Battery Replacement: paso 2, imagen 1 de 3 TDK Life on Record Trek 360 Battery Replacement: paso 2, imagen 2 de 3 TDK Life on Record Trek 360 Battery Replacement: paso 2, imagen 3 de 3
    • Place a metal spudger between the small crease of the battery cover and the device, and apply downward pressure.
    • Pull down like a lever while continuing to apply downward pressure.
  3. TDK Life on Record Trek 360 Battery Replacement: paso 3, imagen 1 de 2 TDK Life on Record Trek 360 Battery Replacement: paso 3, imagen 2 de 2
    • Using a spudger or plastic opening tool, lift the battery from the bottom right and rotate it upwards and toward you.
    • These images show the use of a metal spudger. Use a plastic opening tool or standard spudger to prevent damage to your device.
    • The battery does not lift STRAIGHT UP. Lifting in this manner could damage the battery, wires, and/or the device.
  4. TDK Life on Record Trek 360 Battery Replacement: paso 4, imagen 1 de 3 TDK Life on Record Trek 360 Battery Replacement: paso 4, imagen 2 de 3 TDK Life on Record Trek 360 Battery Replacement: paso 4, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • To remove the battery, use one hand to pull on the battery wires, use tweezers to pull on the connecting head of the speaker.
    • Take extreme caution when pulling. This requires some force, but pulling with extreme force can cause damage to the wire/battery/or device.
Conclusión
3 personas más completaron esta guía.
Helen Huynh
Miembro Desde 09/14/15
338 Reputación
3 Guías creadas
Equipo
CSU Fullerton, Team 1-2, Bruce Fall 2015 Miembro de CSU Fullerton, Team 1-2, Bruce Fall 2015
CSUF-BRUCE-F15S1G2
3 Miembros
5 Guías creadas
2 comentarios
Good guide, but what battery fits?
Niklas Aronsson - Contestar
I have opened the hatch but I can’t lift the battery out. My battery seems to be glued in place…. :(
EDIT: I broke several cheap plastic spudgers, but when I finally used a metallic one, the battery pack came right out. Yes, I read that one shouldn’t use a metallic one, but this battery is dead like the dodo anyway.
Barbafant Fant - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 12
Todo El Tiempo: 3,663
