Saltar al contenido principal
TDK Life on Record A33 AC Adapter Prongs Replacement
Qué necesitas
  1. TDK Life on Record A33 AC Adapter Prongs Replacement, Prongs: paso 1, imagen 1 de 1
    • Locate the small hole, which is in the shape of a semicircle. It is below the plastic piece that has the prongs attached.
  2. TDK Life on Record A33 AC Adapter Prongs Replacement: paso 2, imagen 1 de 2 TDK Life on Record A33 AC Adapter Prongs Replacement: paso 2, imagen 2 de 2
    • Push the button that is inside the hole with the metal spudger and hold it down.
    • While the button is being pressed, push up on the prongs with your thumb. If the prongs aren't moving, you might need to push down a little harder on the button.
    • The button does not need to be pressed when sliding the prongs back in.
  3. TDK Life on Record A33 AC Adapter Prongs Replacement: paso 3, imagen 1 de 1
    • Remove the prongs from the AC Adapter. Any repairs on the prongs can now be easily done.
Conclusión
Una persona más ha completado esta guía.
Matthew Festa
Miembro Desde 10/16/15
808 Reputación
3 Guías creadas
Equipo
UMass Dartmouth, Team 4-2, Catania Fall 2015 Miembro de UMass Dartmouth, Team 4-2, Catania Fall 2015
UMASSD-CATANIA-F15S4G2
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 10
Todo El Tiempo: 2,535
