Saltar al contenido principal
TDK Life on Record A26 Front Faceplate Replacement
Qué necesitas
  1. TDK Life on Record A26 Front Faceplate Replacement, Front Faceplate: paso 1, imagen 1 de 2 TDK Life on Record A26 Front Faceplate Replacement, Front Faceplate: paso 1, imagen 2 de 2
    • Obtain the black plastic spudger to remove the faceplate.
    • Insert the pointed end of the tool inside one of the holes on the faceplate itself.
    • The corner is the best place to start.
    • The faceplate has many little holes so choose one that makes it easier for you.
  2. TDK Life on Record A26 Front Faceplate Replacement: paso 2, imagen 1 de 3 TDK Life on Record A26 Front Faceplate Replacement: paso 2, imagen 2 de 3 TDK Life on Record A26 Front Faceplate Replacement: paso 2, imagen 3 de 3
    • Gently start to lift until the faceplate starts to rise.
    • If you are having trouble getting the faceplate off, continue trying on the rest of the corners until fully removed.
Conclusión
4 personas más completaron esta guía.
Elise Howard
Miembro Desde 10/13/15
831 Reputación
3 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 482
