Introducción
This tutorial will explain how to completely disassemble the TCA PRC 152A radio and accessories.
Disclaimer : Disconnect all peripherals before disassembling.
Qué necesitas
Remove 4 screws on the backpannel
The small retention piece is held by the screw. Be careful not to lose the spring
GPS option (Does not work)
PTT and config button socket
U283 6PIN connector
ON/OFF/Volume knob
Side connector (Does not work)
Microphone attached to the PCB board (1.080KOhm).Can be replaced by POW-2744P-B-R
Speaker FCE 16Ohm 1Watt.
Remove battery stick (18650 Panasonic)
Remove 2 screws
Take off the inner white retainer
Una persona más ha completado esta guía.
