Saltar al contenido principal
T-Mobile Sparq Battery Replacement
Qué necesitas
  1. T-Mobile Sparq Battery Replacement, Battery: paso 1, imagen 1 de 1
    • If you're looking at your phone from the front, feel the upper left hand rounded corner. You'll notice a thin opening between the front of the phone and the back cover.
    • Flip the phone over (as in the picture) and use a spudger or your finger to gently separate the back cover from the phone.
  2. T-Mobile Sparq Battery Replacement: paso 2, imagen 1 de 1
    • Once the back cover has been removed you can see a small groove above the center of the battery. The arrow on the battery is pointing to it.
    • Insert the tip of your finger into the groove and gently lift the battery from the case.
Conclusión
Una persona más ha completado esta guía.
LeAnn Lewis
Miembro Desde 04/07/18
539 Reputación
4 Guías creadas
Equipo
IUPUI, Team S3-G3, Wilson Spring 2018 Miembro de IUPUI, Team S3-G3, Wilson Spring 2018
IUPUI-WILSON-S18S3G3
3 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 9
Todo El Tiempo: 183
