Saltar al contenido principal
T-Mobile Huawei Prism U8651T Digitizer Replacement
Qué necesitas
  1. T-Mobile Huawei Prism U8651T Digitizer Replacement, Remove Back Cover Panel: paso 1, imagen 1 de 3 T-Mobile Huawei Prism U8651T Digitizer Replacement, Remove Back Cover Panel: paso 1, imagen 2 de 3 T-Mobile Huawei Prism U8651T Digitizer Replacement, Remove Back Cover Panel: paso 1, imagen 3 de 3
    • Place the phone face down.
    • Slide the back cover panel away from you, until you hear a click.
    • Lift the back cover panel off.
  2. T-Mobile Huawei Prism U8651T Digitizer Replacement, Remove Battery: paso 2, imagen 1 de 3 T-Mobile Huawei Prism U8651T Digitizer Replacement, Remove Battery: paso 2, imagen 2 de 3 T-Mobile Huawei Prism U8651T Digitizer Replacement, Remove Battery: paso 2, imagen 3 de 3
    • Place the plastic opening tool in the gap between the camera and battery.
    • Pry the battery up.
    • Remove the battery.
  3. T-Mobile Huawei Prism U8651T Digitizer Replacement, Torx Screws: paso 3, imagen 1 de 3 T-Mobile Huawei Prism U8651T Digitizer Replacement, Torx Screws: paso 3, imagen 2 de 3 T-Mobile Huawei Prism U8651T Digitizer Replacement, Torx Screws: paso 3, imagen 3 de 3
    Herramienta utilizada en este paso:
    T4 Torx Screwdriver
    $5.99
    Comprar
    • Locate the six 3mm torx screws holding the plastic mid frame in place.
    • Remove the six torx screws with the T4 torx screwdriver.
  4. T-Mobile Huawei Prism U8651T Digitizer Replacement, Remove Plastic Mid Frame: paso 4, imagen 1 de 3 T-Mobile Huawei Prism U8651T Digitizer Replacement, Remove Plastic Mid Frame: paso 4, imagen 2 de 3 T-Mobile Huawei Prism U8651T Digitizer Replacement, Remove Plastic Mid Frame: paso 4, imagen 3 de 3
    • Place the plastic opening tool in the charging port.
    • Pry up to loosen the bottom edge of the plastic mid frame.
    • Work the plastic opening tool along the seam, until the the plastic mid frame is detached.
    • Remove the plastic mid frame.
  5. T-Mobile Huawei Prism U8651T Digitizer Replacement, Remove Power and Volume Buttons: paso 5, imagen 1 de 2 T-Mobile Huawei Prism U8651T Digitizer Replacement, Remove Power and Volume Buttons: paso 5, imagen 2 de 2
    • Locate the power button.
    • Locate the volume botton.
    • Slide the two buttons up and out of the phone.
    • The removed buttons are incredibly easy to lose, so be sure to keep an eye on them.
  6. T-Mobile Huawei Prism U8651T Digitizer Replacement, Remove Power Button Sensor Strip: paso 6, imagen 1 de 3 T-Mobile Huawei Prism U8651T Digitizer Replacement, Remove Power Button Sensor Strip: paso 6, imagen 2 de 3 T-Mobile Huawei Prism U8651T Digitizer Replacement, Remove Power Button Sensor Strip: paso 6, imagen 3 de 3
    • Locate the power button sensor strip.
    • Place the plastic opening tool under the sensor strip.
    • Pry the sensor strip up.
  7. T-Mobile Huawei Prism U8651T Digitizer Replacement, Remove Volume Button Sensor Strip: paso 7, imagen 1 de 3 T-Mobile Huawei Prism U8651T Digitizer Replacement, Remove Volume Button Sensor Strip: paso 7, imagen 2 de 3 T-Mobile Huawei Prism U8651T Digitizer Replacement, Remove Volume Button Sensor Strip: paso 7, imagen 3 de 3
    • Locate the volume button sensor strip.
  8. T-Mobile Huawei Prism U8651T Digitizer Replacement, Remove Outer Screen Connector: paso 8, imagen 1 de 3 T-Mobile Huawei Prism U8651T Digitizer Replacement, Remove Outer Screen Connector: paso 8, imagen 2 de 3 T-Mobile Huawei Prism U8651T Digitizer Replacement, Remove Outer Screen Connector: paso 8, imagen 3 de 3
    • Locate the outer screen connector.
    • Place the plastic opening tool under the screen connector.
    • Pry the screen connector up.
  9. T-Mobile Huawei Prism U8651T Digitizer Replacement, Remove Inner Screen Connector: paso 9, imagen 1 de 3 T-Mobile Huawei Prism U8651T Digitizer Replacement, Remove Inner Screen Connector: paso 9, imagen 2 de 3 T-Mobile Huawei Prism U8651T Digitizer Replacement, Remove Inner Screen Connector: paso 9, imagen 3 de 3
    • Locate the inner screen connector.
  10. T-Mobile Huawei Prism U8651T Digitizer Replacement, Remove Motherboard: paso 10, imagen 1 de 3 T-Mobile Huawei Prism U8651T Digitizer Replacement, Remove Motherboard: paso 10, imagen 2 de 3 T-Mobile Huawei Prism U8651T Digitizer Replacement, Remove Motherboard: paso 10, imagen 3 de 3
    • Place the plastic opening tool in the charger port.
    • Pry the motherboard up.
    • Remove the motherboard.
  11. T-Mobile Huawei Prism U8651T Digitizer Replacement, Remove Screen: paso 11, imagen 1 de 3 T-Mobile Huawei Prism U8651T Digitizer Replacement, Remove Screen: paso 11, imagen 2 de 3 T-Mobile Huawei Prism U8651T Digitizer Replacement, Remove Screen: paso 11, imagen 3 de 3
    • Pick up the front half of your phone with your left hand.
    • Slowly rotate the phone so the screen falls into your right hand.
    • Be extremely careful not to drop the screen.
  12. T-Mobile Huawei Prism U8651T Digitizer Replacement, Digitizer: paso 12, imagen 1 de 1
    • Be sure to use the new digitizer when reassembling your phone.
Conclusión
5 personas más completaron esta guía.
Dillon
Miembro Desde 10/23/14
578 Reputación
5 Guías creadas
Equipo
Michigan Tech, Team 1-7, Lauer Fall 2014 Miembro de Michigan Tech, Team 1-7, Lauer Fall 2014
MTU-LAUER-F14S1G7
3 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 3
Todo El Tiempo: 579
