Saltar al contenido principal
T-Mobile Huawei Prism U8651T Battery Replacement
Qué necesitas
  1. T-Mobile Huawei Prism U8651T Battery Replacement, Remove Back Cover Panel: paso 1, imagen 1 de 3 T-Mobile Huawei Prism U8651T Battery Replacement, Remove Back Cover Panel: paso 1, imagen 2 de 3 T-Mobile Huawei Prism U8651T Battery Replacement, Remove Back Cover Panel: paso 1, imagen 3 de 3
    • Place the phone face down.
    • Slide the back cover panel away from you, until you hear a click.
    • Lift the back cover panel off.
  2. T-Mobile Huawei Prism U8651T Battery Replacement, Remove Battery: paso 2, imagen 1 de 3 T-Mobile Huawei Prism U8651T Battery Replacement, Remove Battery: paso 2, imagen 2 de 3 T-Mobile Huawei Prism U8651T Battery Replacement, Remove Battery: paso 2, imagen 3 de 3
    • Place the plastic opening tool in the gap between the camera and battery.
    • Pry the battery up.
    • Remove the battery.
    • Be sure to use the new battery during reassembly.
Conclusión
Dillon
Miembro Desde 10/23/14
578 Reputación
5 Guías creadas
Equipo
Michigan Tech, Team 1-7, Lauer Fall 2014 Miembro de Michigan Tech, Team 1-7, Lauer Fall 2014
MTU-LAUER-F14S1G7
3 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 626
