Saltar al contenido principal
System76 Serval WS Cooling Fan Replacement
Qué necesitas
  1. System76 Serval WS Cooling Fan Replacement, Cooling Fan: paso 1, imagen 1 de 1
    • Unplug the power supply and remove the battery from the device before proceeding.
    • Unscrew and remove the 4 screws circled in red. Then remove the plastic bottom panel.
  2. System76 Serval WS Cooling Fan Replacement: paso 2, imagen 1 de 2 System76 Serval WS Cooling Fan Replacement: paso 2, imagen 2 de 2
    • Remove the numbered screws in order to safely remove the heatsink
    • Remove the heatsink to access the cooling fans.
    • During reassembly, make sure to tighten the heatsink screws in the order indicated by the labeled numbers.
  3. System76 Serval WS Cooling Fan Replacement: paso 3, imagen 1 de 1
    • Unscrew and remove the screws circled in red, 3 screws per fan.
    • Next unplug the 4-pin power connectors, marked in orange squares.
    • Remove the cooling fans by lifting them up and out of the casing.
  4. System76 Serval WS Cooling Fan Replacement: paso 4, imagen 1 de 2 System76 Serval WS Cooling Fan Replacement: paso 4, imagen 2 de 2
    • Plug in the 4-pin power connectors of the new fans.
    • Insert and tighten 3 screws per fan.
    • If needed, clean off the old thermal paste from the CPU, GPU, and heatsink using isopropyl alcohol and a microfiber cloth. Apply new thermal paste before reassembly.
    • Clean the dust from the heatsink fins.
Conclusión
Oliver Anderson
Miembro Desde 03/26/19
289 Reputación
3 Guías creadas
Equipo
Un comentario
What model of fan would one buy to replace this?
CrustyTrombone - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 8
Ultimos 30 días: 18
Todo El Tiempo: 531
