Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Syntus ST150 Ultrasonic Plate Replacement
Qué necesitas
    1. Syntus ST150 Ultrasonic Plate Replacement, Ultrasonic Plate: paso 1, imagen 1 de 1
      • First, make sure the water tank inside the diffuser is completely dry to avoid any water from contacting the internal components.
      • Make sure the diffuser is disconnected from the power source to avoid electrical hazards.
      Pregunta a FixBot
      Agregar Comentario
    2. Syntus ST150 Ultrasonic Plate Replacement: paso 2, imagen 1 de 2 Syntus ST150 Ultrasonic Plate Replacement: paso 2, imagen 2 de 2
      • With a Phillips #1 screwdriver, remove the three 10 mm screws on the bottom of the diffuser.
      Pregunta a FixBot
      Agregar Comentario
    3. Syntus ST150 Ultrasonic Plate Replacement: paso 3, imagen 1 de 3 Syntus ST150 Ultrasonic Plate Replacement: paso 3, imagen 2 de 3 Syntus ST150 Ultrasonic Plate Replacement: paso 3, imagen 3 de 3
      • Lift the water tank while holding the base of the diffuser.
      • Disconnect the three cables form the board.
      • Make sure when reassembling the diffuser to plug in each cable to its assigned port.
      Pregunta a FixBot
      Agregar Comentario
    4. Syntus ST150 Ultrasonic Plate Replacement: paso 4, imagen 1 de 3 Syntus ST150 Ultrasonic Plate Replacement: paso 4, imagen 2 de 3 Syntus ST150 Ultrasonic Plate Replacement: paso 4, imagen 3 de 3
      • To separate the board from the water tank, unscrew the three Phillips #1 10 mm screws securing the board.
      Pregunta a FixBot
      Agregar Comentario
    5. Syntus ST150 Ultrasonic Plate Replacement: paso 5, imagen 1 de 3 Syntus ST150 Ultrasonic Plate Replacement: paso 5, imagen 2 de 3 Syntus ST150 Ultrasonic Plate Replacement: paso 5, imagen 3 de 3
      • With a Phillips #0 screwdriver, remove the three 7 mm screws from the ultrasonic sensor cover.
      • Remove the cover to expose the ultrasonic sensor.
      Pregunta a FixBot
      Agregar Comentario
    6. Syntus ST150 Ultrasonic Plate Replacement: paso 6, imagen 1 de 3 Syntus ST150 Ultrasonic Plate Replacement: paso 6, imagen 2 de 3 Syntus ST150 Ultrasonic Plate Replacement: paso 6, imagen 3 de 3
      • Detach the ultrasonic sensor from the water tank.
      • Detach the ultrasonic sensor connector from the board.
      Pregunta a FixBot
      Agregar Comentario
    7. Syntus ST150 Ultrasonic Plate Replacement: paso 7, imagen 1 de 1
      • Remove the rubber cover from the ultrasonic plate.
      Pregunta a FixBot
      Agregar Comentario
    8. Syntus ST150 Ultrasonic Plate Replacement: paso 8, imagen 1 de 1
      • Now you can replace the ultrasonic plate of your diffuser.
      Pregunta a FixBot
      Agregar Comentario
Conclusión
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 30
Ultimos 30 días: 105
Todo El Tiempo: 1,894
