Saltar al contenido principal
Introducción
Use this guide to replace the RAM.
The processor in the DS412+ supports DDR3 800/1066MHz RAM modules
  1. DS412+ Remove the front panel
    • DS412+
    • Remove the front panel
  2. Remove the hard disks
    • Remove the hard disks
  3. Remove the two screws in the back of the NAS, on the top and bottom. Remove the two screws in the back of the NAS, on the top and bottom.
    • Remove the two screws in the back of the NAS, on the top and bottom.
  4. Locate those 2 tabs on the left side inside the device. Lift them up off the metal brace
    • Locate those 2 tabs on the left side inside the device.
    • Lift them up off the metal brace
    • You may have to bend the metal support bar to remove the case. Bend it back if you do.
  5. Push the case away towards the back about 1 cm Push the case away towards the back about 1 cm
    • Push the case away towards the back about 1 cm
  6. With the NAS on its right side, lift up the enclosure, mind the tabs on the top of the case. With the NAS on its right side, lift up the enclosure, mind the tabs on the top of the case.
    • With the NAS on its right side, lift up the enclosure, mind the tabs on the top of the case.
  7. Remove the screw securing the HDD bays enclosure. Remove the screw securing the HDD bays enclosure.
    • Remove the screw securing the HDD bays enclosure.
  8. Remove the screw securing the I/O board.
    • Remove the screw securing the I/O board.
  9. Remove the four screws securing the HDD bays Remove the four screws securing the HDD bays
    • Remove the four screws securing the HDD bays
  10. Pull the fan a little bit away Pull the fan a little bit away
    • Pull the fan a little bit away
  11. Watch out for this plug Lift the metal bracket out
    • Watch out for this plug
    • Lift the metal bracket out
  12. Remove the fan power headers Remove the fan power headers
    • Remove the fan power headers
  13. Remove the I/O board by lifting it up
    • Remove the I/O board by lifting it up
  14. Remove those 4 screws Remove those 4 screws
    • Remove those 4 screws
  15. Starting from the front of the unit, remove the motherboard from the unit.
    • Starting from the front of the unit, remove the motherboard from the unit.
  16. Pull these tabs and remove the ram Old and new Ram The old RAM's part number is: M3SN-1GSFCCM7-GA14
    • Pull these tabs and remove the ram
    • Old and new Ram
    • The old RAM's part number is: M3SN-1GSFCCM7-GA14
    • To reassemble your device, follow these instructions in reverse order.
Conclusión
33 personas más completaron esta guía.
gieljnssns
Miembro Desde 26/06/11
925 Reputación
1 Guía escrita
Hi is it also possible with a Synology ds216play? Or is the RAM not modular in this Drives?
markusguenther30684 - Contestar
Very nice guide. Thank you!
mbs - Contestar
Thank you for the guide, just to ease it up a bit for everybody following, the best way to pull the two tabs from step 4 was to use small spoon (or anything metal) and use it as a crowbar from the inside (do not try to put force from the outer rim, but really from inside of the Synology itself (against the metal beam the tabs are holding to).
Ondrej Palat - Contestar
Thank you very much.
Olivier Claude - Contestar
did these steps and now my DS412+ won't boot anymore. just the blue power light for a few seconds, no hard drive or fan will turn on.
after putting the old RAM in the slot nothing changed. cannot find any error, how do I find out what's wrong here???
Andreas Hanny - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 26
Ultimos 30 días: 167
Todo El Tiempo: 17,345
