Saltar al contenido principal
Syma S107 Gyro Replacement
Qué necesitas
  1. Syma S107 Gyro Replacement, Counterweight Bar: paso 1, imagen 1 de 2 Syma S107 Gyro Replacement, Counterweight Bar: paso 1, imagen 2 de 2
    • Using tweezers, gently remove the two stabilizing links by pulling straight away from the point of connection.
  2. Syma S107 Gyro Replacement: paso 2, imagen 1 de 2 Syma S107 Gyro Replacement: paso 2, imagen 2 de 2
    • Remove the counterweight bar by removing the screw.
    • One 10.1mm Phillips #0.
  3. Syma S107 Gyro Replacement, Gyro Carriage: paso 3, imagen 1 de 2 Syma S107 Gyro Replacement, Gyro Carriage: paso 3, imagen 2 de 2
    • Remove the gyro carriage by removing the following screws:
    • Two 5.6mm Phillips #0.
    • When reinstalling these screws make sure to line up one screw with the keyway on the main rotor shaft.
  4. Syma S107 Gyro Replacement: paso 4, imagen 1 de 2 Syma S107 Gyro Replacement: paso 4, imagen 2 de 2
    • Gently remove the broken gyro carriage by pulling up.
    • Remove blade assembly by simply sliding it up and off the shaft.
  5. Syma S107 Gyro Replacement, Blade Carriage: paso 5, imagen 1 de 3 Syma S107 Gyro Replacement, Blade Carriage: paso 5, imagen 2 de 3 Syma S107 Gyro Replacement, Blade Carriage: paso 5, imagen 3 de 3
    • Again using tweezers gently remove the stabilizing links from the blade carriage by pulling straight away from the point of connection.
  6. Syma S107 Gyro Replacement: paso 6, imagen 1 de 2 Syma S107 Gyro Replacement: paso 6, imagen 2 de 2
    • Remove the blades from the blade carriage by removing the following screws:
    • Two 4.7mm Phillips #0.
  7. Syma S107 Gyro Replacement: paso 7, imagen 1 de 2 Syma S107 Gyro Replacement: paso 7, imagen 2 de 2
    • Remove the following screws:
    • Two 4.5mm Phillips #0.
    • Make sure to remove any broken plastic pins before reassembling the components.
    • You will have to slide the two halves of the blade carriage over the pins on the gyro carriage first when reassembling.
Conclusión
7 personas más completaron esta guía.
Christopher Smith
Miembro Desde 10/11/14
305 Reputación
1 Guía escrita
Equipo
USF Tampa, Team 1-31, Donnelly Fall 2014 Miembro de USF Tampa, Team 1-31, Donnelly Fall 2014
USFT-DONNELLY-F14S1G31
1 Miembro
1 Guía escrita
6 comentarios
Thank you for this guide! This has fixed the issue and made a 35 year old boy very happy!
Patrick haymer - Contestar
Cheers thanks too this page I fixed problem  great ,  Martin
Martin Worboys - Contestar
Same here, incidentally where can I get replacement batteries please? Also have a “Picolo” heli with a bad feedback IC , supposedly this part can also be replaced on some units as its a soldered vertical board on the main.
Andre - Contestar
Thank you! Took forever to find an answer to my problem! Now very obvious thanks to you. My sanity is restored! HaHa!
CRC 04/04/2021
Chris - Contestar
I’m halfway there and grateful for the directions. But I’m not having any luck removing the broken plastic pins from the blade carriage. I’ve tried using a needle but no luck. Did anyone else come up against this?
Adam Leavesley - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 8
Ultimos 30 días: 46
Todo El Tiempo: 14,237
