Saltar al contenido principal
Swann Wi-Fi Indoor Security Camera Motion Sensor Replacement
Qué necesitas
  1. Swann Wi-Fi Indoor Security Camera Motion Sensor Replacement, Case: paso 1, imagen 1 de 3 Swann Wi-Fi Indoor Security Camera Motion Sensor Replacement, Case: paso 1, imagen 2 de 3 Swann Wi-Fi Indoor Security Camera Motion Sensor Replacement, Case: paso 1, imagen 3 de 3
    • Use the Phillips #0 to remove the screw located on the back of the camera above the mount.
    • Slide the mount out from the bottom of the device.
  2. Swann Wi-Fi Indoor Security Camera Motion Sensor Replacement: paso 2, imagen 1 de 1
    • Remove the back of the case by placing a iFixit opening tool underneath the edge of the case and prying it up.
  3. Swann Wi-Fi Indoor Security Camera Motion Sensor Replacement: paso 3, imagen 1 de 1
    • Carefully remove the back of the case without pulling the cables connected to the motherboard and the speaker on the back of the case.
  4. Swann Wi-Fi Indoor Security Camera Motion Sensor Replacement, Motion Sensor: paso 4, imagen 1 de 3 Swann Wi-Fi Indoor Security Camera Motion Sensor Replacement, Motion Sensor: paso 4, imagen 2 de 3 Swann Wi-Fi Indoor Security Camera Motion Sensor Replacement, Motion Sensor: paso 4, imagen 3 de 3
    • Facing the inside of the front of the case, release the white ribbon cable by pulling the black rectangular connector at the end of the connection
    • Once the black holder is opened, gently pull the cable out of the holder.
  5. Swann Wi-Fi Indoor Security Camera Motion Sensor Replacement: paso 5, imagen 1 de 1
    • Facing the back of the small board, remove the two 2.0 mm Phillips #0 black screws that connect it to the back of the case.
  6. Swann Wi-Fi Indoor Security Camera Motion Sensor Replacement: paso 6, imagen 1 de 1
    • Carefully use a soldering iron to melt the solder in three places that connect the motion sensor. For more information on soldering follow this helpful guide.
    • Pull the sensor out from the motherboard.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 33
Todo El Tiempo: 362
