Saltar al contenido principal
Swann Doorphone Video Intercom Microphone Replacement
Qué necesitas
  1. Swann Doorphone Video Intercom Microphone Replacement, Microphone: paso 1, imagen 1 de 3 Swann Doorphone Video Intercom Microphone Replacement, Microphone: paso 1, imagen 2 de 3 Swann Doorphone Video Intercom Microphone Replacement, Microphone: paso 1, imagen 3 de 3
    • Flip the monitor of the Swann Doorphone Video Intercom over so that the underside is facing up.
    • Remove the six 2 mm corner screws from the back plate of the monitor using the JIS #0 screwdriver.
  2. Swann Doorphone Video Intercom Microphone Replacement: paso 2, imagen 1 de 2 Swann Doorphone Video Intercom Microphone Replacement: paso 2, imagen 2 de 2
    • Once the screws are removed, grip the black back plate of the monitor and remove from the monitor.
    • The back plate will still be connected to the monitor with a cord of wires that should not be removed.
  3. Swann Doorphone Video Intercom Microphone Replacement: paso 3, imagen 1 de 3 Swann Doorphone Video Intercom Microphone Replacement: paso 3, imagen 2 de 3 Swann Doorphone Video Intercom Microphone Replacement: paso 3, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • Using the precision tweezers, grab the sides of the white connector at the bottom of the green board.
    • Pull the white connector towards you to disconnect the board.
  4. Swann Doorphone Video Intercom Microphone Replacement: paso 4, imagen 1 de 3 Swann Doorphone Video Intercom Microphone Replacement: paso 4, imagen 2 de 3 Swann Doorphone Video Intercom Microphone Replacement: paso 4, imagen 3 de 3
    • Grip the other end of the white connector cable towards the base of the black microphone.
    • Pull gently towards your body to remove the microphone.
Conclusión
Emily Stenke
Miembro Desde 02/14/18
555 Reputación
4 Guías creadas
Equipo
USF Tampa, Team S2-G4, Eyestone Spring 2018 Miembro de USF Tampa, Team S2-G4, Eyestone Spring 2018
USFT-EYESTONE-S18S2G4
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 5
Ultimos 30 días: 11
Todo El Tiempo: 350
