Saltar al contenido principal
Swagtron T3 Gyroscope Replacement
Qué necesitas
  1. Swagtron T3 Gyroscope Replacement, Cover: paso 1, imagen 1 de 2 Swagtron T3 Gyroscope Replacement, Cover: paso 1, imagen 2 de 2
    • Make sure the hoverboard is completely powered off and unplugged from any outlets.
    • Flip the Swagtron so that the footpads are facing the ground.
    • Unscrew the sixteen 9.4 mm Phillips #1 machine screws on the side of the Swagtron that is now facing upwards.
  2. Swagtron T3 Gyroscope Replacement: paso 2, imagen 1 de 3 Swagtron T3 Gyroscope Replacement: paso 2, imagen 2 de 3 Swagtron T3 Gyroscope Replacement: paso 2, imagen 3 de 3
    • Be careful with the small blue capacitors indicated by the orange box. There are many of these capacitors in the device.
    • Slowly lift the backside cover.
    • Both sides lift up the same way, but the motherboard is under one side and the battery is under the other.
    • Detach the four cables connected to the cover by pinching the connector clips and pulling the cables out:
    • Three cables on the motherboard side.
    • Two red cables with white connectors and one white cable with a white connector.
    • One yellow cable with a black connector on the battery side.
    • After detachment, you should be able to completely remove the backside cover.
  3. Swagtron T3 Gyroscope Replacement, Gyroscope: paso 3, imagen 1 de 1
    • The gyroscope is a blue rectangular circuit board on top of a white base and is closest to the wheel.
    • Detach the four cables connecting the gyroscope to the hoverboard by pinching the connector clips and pulling the cables out:
    • Three red and black cables with white connectors.
    • One multicolored cable with a black connector.
  4. Swagtron T3 Gyroscope Replacement: paso 4, imagen 1 de 1
    • Uncrew the four 7.2 mm Phillips #1 self-drilling screws connecting the blue gyroscope to the white plastic holding piece.
  5. Swagtron T3 Gyroscope Replacement: paso 5, imagen 1 de 2 Swagtron T3 Gyroscope Replacement: paso 5, imagen 2 de 2
    • Cut the plastic cable tie holding the cables together with utility scissors.
    • Disconnect the blue/green cable from the blue/white cable by pinching the connector clips and pulling the cables apart.
  6. Swagtron T3 Gyroscope Replacement: paso 6, imagen 1 de 1
    • Gently lift the blue gyroscope off of the white plastic holder piece.
    • After reassembling the Swagtron with the new gyroscope, check to make sure your Swagtron is balancing properly.
    • If it is still unbalanced, repeat all steps in this guide with the gyroscope by the other wheel.
Conclusión
3 personas más completaron esta guía.
Emily Richter
Miembro Desde 04/10/17
351 Reputación
1 Guía escrita
Equipo
Cal Poly, Team S13-G3, Forte Spring 2017 Miembro de Cal Poly, Team S13-G3, Forte Spring 2017
CPSU-FORTE-S17S13G3
4 Miembros
4 Guías creadas
3 comentarios
Where can one buy the new gyroscope?
Mike - Contestar
Where is the best place to buy the gyroscope for the T3?
I see Ebay sells complete kits with motherboards and all.
Are they compatible?
Mike - Contestar
where can I buy new gyroscope
roccovalletta - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 8
Ultimos 30 días: 26
Todo El Tiempo: 4,582
