Saltar al contenido principal
Swagtron T3 Cover Replacement
Sólo Prerrequisito
Esta guía solo debería usarse como prerrequisito para otras guías. Por tanto, estará incompleta.
Qué necesitas
  1. Swagtron T3 Cover Replacement, Cover: paso 1, imagen 1 de 2 Swagtron T3 Cover Replacement, Cover: paso 1, imagen 2 de 2
    • Make sure the hoverboard is completely powered off and unplugged from any outlets.
    • Flip the Swagtron so that the footpads are facing the ground.
    • Unscrew the sixteen 9.4 mm Phillips #1 machine screws on the side of the Swagtron that is now facing upwards.
  2. Swagtron T3 Cover Replacement: paso 2, imagen 1 de 3 Swagtron T3 Cover Replacement: paso 2, imagen 2 de 3 Swagtron T3 Cover Replacement: paso 2, imagen 3 de 3
    • Be careful with the small blue capacitors indicated by the orange box. There are many of these capacitors in the device.
    • Slowly lift the backside cover.
    • Both sides lift up the same way, but the motherboard is under one side and the battery is under the other.
    • Detach the four cables connected to the cover by pinching the connector clips and pulling the cables out:
    • Three cables on the motherboard side.
    • Two red cables with white connectors and one white cable with a white connector.
    • One yellow cable with a black connector on the battery side.
    • After detachment, you should be able to completely remove the backside cover.
Conclusión
Klara Perkins
Miembro Desde 04/10/17
412 Reputación
2 Guías creadas
Equipo
Cal Poly, Team S13-G3, Forte Spring 2017 Miembro de Cal Poly, Team S13-G3, Forte Spring 2017
CPSU-FORTE-S17S13G3
4 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 17
Ultimos 30 días: 37
Todo El Tiempo: 4,758
