Saltar al contenido principal
SwagTron T1 Wheel Replacement
Qué necesitas
  1. SwagTron T1 Wheel Replacement, Back Panels: paso 1, imagen 1 de 1
    • Ensure that the SwagTron is off.
    • Turn the SwagTron upside down to see the underside.
  2. SwagTron T1 Wheel Replacement: paso 2, imagen 1 de 3 SwagTron T1 Wheel Replacement: paso 2, imagen 2 de 3 SwagTron T1 Wheel Replacement: paso 2, imagen 3 de 3
    • Unscrew the eighteen 10mm screws that secure the back panels using a Phillips #2 screwdriver.
    • The screws are tightly in place. It will take effort to screw them out.
    • The panel is still attached to the SwagTron by wires that go to the motherboard.
    • Carefully lift the panels off
  3. SwagTron T1 Wheel Replacement: paso 3, imagen 1 de 3 SwagTron T1 Wheel Replacement: paso 3, imagen 2 de 3 SwagTron T1 Wheel Replacement: paso 3, imagen 3 de 3
    • Follow the wires from the panels to the motherboard.
    • You may need to cut any zip ties that are holding the wires together.
    • There is one connection on the battery side and three on the other side that must be removed.
    • These connections may be difficult to remove. Try to securely press the connection and pull firmly.
    • Your back panels are now completely removed.
  4. SwagTron T1 Wheel Replacement, Wheel: paso 4, imagen 1 de 3 SwagTron T1 Wheel Replacement, Wheel: paso 4, imagen 2 de 3 SwagTron T1 Wheel Replacement, Wheel: paso 4, imagen 3 de 3
    • Using your Phillips #2 screwdriver, remove the four 1cm screws that attach the gyroscope and its black case to the hoverboard.
    • Carefully remove this component and set it off to the side.
  5. SwagTron T1 Wheel Replacement: paso 5, imagen 1 de 3 SwagTron T1 Wheel Replacement: paso 5, imagen 2 de 3 SwagTron T1 Wheel Replacement: paso 5, imagen 3 de 3
    • Using your H 6.0 allen wrench, remove the four 20mm black bolts shown in the picture.
    • Take off the iron plate holding the wheel in place.
    • Remove the Motor/Wheel and set it aside close by to the hoverboard.
    • The wires from the Motor/Wheel should still be connected to the motherboard.
    • These bolts are very tight, it may be difficult to remove them. Try using a tool with a long handle.
  6. SwagTron T1 Wheel Replacement: paso 6, imagen 1 de 3 SwagTron T1 Wheel Replacement: paso 6, imagen 2 de 3 SwagTron T1 Wheel Replacement: paso 6, imagen 3 de 3
    • Slide the protective plastic off the connectors on the marked wires (green, blue, and yellow) using your hands or a set of tweezers.
    • The connectors on the wires of your hoverboard may be different from those shown in the pictures on the left due to differences in manufacturing.
    • Separate the set of marked green, blue, and yellow wires from their connectors.
  7. SwagTron T1 Wheel Replacement: paso 7, imagen 1 de 3 SwagTron T1 Wheel Replacement: paso 7, imagen 2 de 3 SwagTron T1 Wheel Replacement: paso 7, imagen 3 de 3
    • Finally separate the last connector shown on the left.
    • Your wheel is completely removed; slide in a new Motor/Wheel into the slot and follow the previous steps in reverse order.
    • Make sure the replacement wheel is snug. Neither rubbing on the outer rim nor on the side of the hoverboard.
Conclusión
4 personas más completaron esta guía.
Teagan Allen
Miembro Desde 04/18/17
426 Reputación
2 Guías creadas
Equipo
Cal Poly, Team S17-G5, Banghart Spring 2017 Miembro de Cal Poly, Team S17-G5, Banghart Spring 2017
CPSU-BANGHART-S17S17G5
4 Miembros
5 Guías creadas
3 comentarios
Where do you get replacement wheels?
Elizabeth Schumacher - Contestar
Where can we find replacement wheels?
Liz Vance - Contestar
Mine won't stop beeping?? Fully charged.
Rachael Anderson - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 17
Todo El Tiempo: 5,604
