Saltar al contenido principal
SwagTron T1 Back Panels Replacement
Qué necesitas
  1. SwagTron T1 Back Panels Replacement, Back Panels: paso 1, imagen 1 de 1
    • Ensure that the SwagTron is off.
    • Turn the SwagTron upside down to see the underside.
  2. SwagTron T1 Back Panels Replacement: paso 2, imagen 1 de 3 SwagTron T1 Back Panels Replacement: paso 2, imagen 2 de 3 SwagTron T1 Back Panels Replacement: paso 2, imagen 3 de 3
    • Unscrew the eighteen 10mm screws that secure the back panels using a Phillips #2 screwdriver.
    • The screws are tightly in place. It will take effort to screw them out.
    • The panel is still attached to the SwagTron by wires that go to the motherboard.
    • Carefully lift the panels off
  3. SwagTron T1 Back Panels Replacement: paso 3, imagen 1 de 3 SwagTron T1 Back Panels Replacement: paso 3, imagen 2 de 3 SwagTron T1 Back Panels Replacement: paso 3, imagen 3 de 3
    • Follow the wires from the panels to the motherboard.
    • You may need to cut any zip ties that are holding the wires together.
    • There is one connection on the battery side and three on the other side that must be removed.
    • These connections may be difficult to remove. Try to securely press the connection and pull firmly.
    • Your back panels are now completely removed.
Conclusión
Adrian Abarca
Miembro Desde 04/18/17
360 Reputación
2 Guías creadas
Equipo
Cal Poly, Team S17-G5, Banghart Spring 2017 Miembro de Cal Poly, Team S17-G5, Banghart Spring 2017
CPSU-BANGHART-S17S17G5
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 4
Ultimos 30 días: 8
Todo El Tiempo: 669
