Saltar al contenido principal
Introducción
Use this guide to remove the exhaust pipe from your Suzuki FA50 moped.
  1. Use a #2 Phillips screwdriver to remove the heat shield from the muffler.
    • Use a #2 Phillips screwdriver to remove the heat shield from the muffler.
  2. Kits de Reparación de Batería de MacBook Air
    A partir de $69.99
    Buy Now
    A partir de $69.99
    Buy Now
  3. There are two 10 mm hex nuts attaching the muffler to the engine. Make sure you remove both of them before proceeding to the next step.
    • There are two 10 mm hex nuts attaching the muffler to the engine. Make sure you remove both of them before proceeding to the next step.
    • Use a 10 mm socket wrench to unscrew the two hex nuts.
  4. Use a 12 mm socket wrench to unscrew the third and final hex nut that holds the muffler in place.
    • Use a 12 mm socket wrench to unscrew the third and final hex nut that holds the muffler in place.
    • Make sure to support the muffler with your hand while removing this nut, otherwise it may just fall to the floor.
Conclusión
Una persona más ha completado esta guía.
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 6
Últimos 30 Días: 30
Todo El Tiempo: 6,150
