Introducción
Si sus auriculares Monster DNA reproducen ruido de un solo lado, es probable que haya un cable suelto y que debas soldarlo. Esto sucede con frecuencia porque las pequeñas tensiones en el cable pueden aflojar fácilmente las uniones de soldadura. Para ello, debes desmontar el auricular y volver a conectar los cables.
Qué necesitas
Para volver a armar tu dispositivo, sigue estas instrucciones en orden inverso.
Una persona más ha completado esta guía.
Un agradecimiento especial a estos traductores:
100%
¡ Francisco Javier Saiz Esteban nos está ayudando a reparar el mundo! ¿Quieres contribuir?
Empezar a traducir ›
2 comentarios
any ways on being able to know which side its on in particular without having to open both sides?
I broke the plate which holds the ear muffs on, by following these directions.
On Step 3, you have the spudger in the wrong location. You are supposed to put the prying bar or spudger before or after the silver ring which acts as a spacer for the speaker housing. I like to pry in the space between the silver ring and the audio jack.
Pics look good but you will have replace the one in step 3 showing the correct location to pry from. Others too will brake the same ring I did hence your warning about damage to the headphones if applying too much pressure.
Dan
