Introducción
Hola a todos: En esta guía, os mostraré cómo reemplazar el ensamblaje del cardán o la carcasa del cardán en el dron DJI Mini 3 Pro.
Después de reemplazar la cámara cardán, es posible que debas calibrar tu dron, pero esto no se puede hacer con la aplicación móvil DJI Fly, deberás usar un software adicional. Para calibrar el cardán mira este video tutorial https://youtu.be/mu03HWXplM4
Qué necesitas
Para volver a armar tu dispositivo, sigue estas instrucciones.
5 personas más completaron esta guía.
Un agradecimiento especial a estos traductores:
100%
¡ Francisco Javier Saiz Esteban nos está ayudando a reparar el mundo! ¿Quieres contribuir?
Empezar a traducir ›
9 comentarios
Does anyone have a source for replacing the little rubber gimbal mounts?
Andre Purdy - Contestar
HI there! Does anyone know where I can buy the whole gimbal in USA? I remember seeing it somewhere but cannot find it
gbonilla - Contestar
Go to YouTube and check the link to the gimbal assembly in the description below the video
Arty -
mini 3 pro com port not show on device manegar any help.
Limon Khan - Contestar
Start trembling during flight after a horizontal stop. At the start, I can hear the gimbal noise from trembling (before taking off). I gently touch it, and it stops. I take off and fly a long distance.
If I stop it or it stops it by signal loss, the trembling starts again. if I never stop it and take gentle curves back, it may work. At abrupt stops, it starts trembling. I bring the drone back to me at 1-meter height. I gently touch the gimbal (without landing), and it stops. Then I fly again (if the battery is low, I land, change the battery, and start again, same steps, every time). I will probably buy a new one, so I can send this to repairs - did not check the guarantee yet.
- no problems during climbing up.
- only on horizontal movements and hard stops (release the lever on the controller).
I will try never to release the lever abruptly and never lose signal (a signal lost could be a hard brake, also)
??? Calibration can stop this strange error ????
Dorin - Contestar
