Esta traducción la ha hecho un programa y todavía no la ha revisado nadie. ¿Hablas este idioma? Échale un vistazo.
Introducción
Esta guía demostrará cómo quitar la tapa trasera de la tableta Galaxy Tab S 10.5. Este es un paso de guía de prerrequisitos para la mayoría de los problemas internos de este dispositivo. Tendrás que quitar la tapa trasera antes de poder acceder a muchos componentes.
Qué necesitas
Introduce la herramienta de apertura de plástico en la ranura de la tarjeta SD o en el puerto de carga.
Intenta hacer palanca hacia arriba hasta que veas una separación entre la tableta y la tapa trasera.
Para volver a montar tu dispositivo, sigue estas instrucciones en orden inverso.
21 personas más completaron esta guía.
6Guía Comentarios
This is very misleading and not the correct way to open this device. This will damage the backplate and the antennas that are glued together. The proper way to open this tablet is from the front taking the LCD out of the frame.
I disassembled and assembled back SM-T805 for motherboard replacement 2 hours ago. Discovered that back cover have a row of tiny pins with tips molded into back cover rim who are designed to break out and larger pins who will click open and back on closing just fine. Also back cover rim is glued to cover with weak glue. Seems someone Samsung decided that those larger pins alone are not enough to keep back cover firmly in place without flapping around. In reality larger pins alone on assembling will click back and keep cover in place just fine.
However I agree to you that correct way is to carefully open this tablet from screen side with these small blue flat openers or with plastic cards. It will be faster as well. Back cover rim should be removed only to replace antennas. I hope that author of these manuals will fix that.
Jamee is right, the SM-T805 (3G) can be opened separating the cover from the LCD, and not by removing that back cover that is glued to the rest.
How can I get another charging female component
