Saltar al contenido principal
Surfboard Traction Pad Replacement
Qué necesitas
  1. Surfboard Traction Pad Replacement, Traction Pad: paso 1, imagen 1 de 2 Surfboard Traction Pad Replacement, Traction Pad: paso 1, imagen 2 de 2
    • Apply protective gloves.
  2. Surfboard Traction Pad Replacement: paso 2, imagen 1 de 3 Surfboard Traction Pad Replacement: paso 2, imagen 2 de 3 Surfboard Traction Pad Replacement: paso 2, imagen 3 de 3
    • Pull up the traction pad from the surfboard.
    • This allows for an easy start to cutting the adhesive.
  3. Surfboard Traction Pad Replacement: paso 3, imagen 1 de 2 Surfboard Traction Pad Replacement: paso 3, imagen 2 de 2
    • Using a razor blade, cut away at the adhesive under the traction pad.
  4. Surfboard Traction Pad Replacement: paso 4, imagen 1 de 2 Surfboard Traction Pad Replacement: paso 4, imagen 2 de 2
    • Completely remove each section of the traction pad leaving only excess adhesive.
  5. Surfboard Traction Pad Replacement: paso 5, imagen 1 de 3 Surfboard Traction Pad Replacement: paso 5, imagen 2 de 3 Surfboard Traction Pad Replacement: paso 5, imagen 3 de 3
    • Apply adhesive remover to the paper towels.
    • Apply the paper towels to the section of the board with excess adhesive until it is covered.
    • Let it stand for 5 minutes.
  6. Surfboard Traction Pad Replacement: paso 6, imagen 1 de 3 Surfboard Traction Pad Replacement: paso 6, imagen 2 de 3 Surfboard Traction Pad Replacement: paso 6, imagen 3 de 3
    • Remove the paper towels from the board.
    • Cut away the rest of the excess adhesive.
    • Dry the board with paper towels.
Conclusión
Now the tail of your board is clean and ready for a new traction pad.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 10
Todo El Tiempo: 405
