Introducción
This is a guide to replace your devices surflink port. This is a simple and short guide that doesn't require many tools. You may need to replace the surflink ort if it is unresponsive, but don't worry as this guide will only take a short amount of time.
Qué necesitas
Disconnect the battery cable by lifting the pull tab until it "clicks."
Remove the left I/O bracket by unscrewing the the three M1109237 screws with your T3 Torx Screwdriver.
Un comentario
Dont even bother reading this unless you already have aquired the surflink port. They are basically impossible to get the parts through ifixit and microsoft. in europe at least.
