Saltar al contenido principal
Surface Laptop Studio SSD Replacement
Qué necesitas
  1. Surface Laptop Studio SSD Replacement, Lower Case: paso 1, imagen 1 de 1
    Herramienta utilizada en este paso:
    Comprar
    • Remove the rubber cosmetic strip along the outside edge of the back plate with tweezers.
  2. Surface Laptop Studio SSD Replacement: paso 2, imagen 1 de 2 Surface Laptop Studio SSD Replacement: paso 2, imagen 2 de 2
    • Remove the two rubber feet on the lower case with an opening tool.
  3. Surface Laptop Studio SSD Replacement: paso 3, imagen 1 de 1
    • Remove the two screws with a T3 Torx screwdriver.
  4. Surface Laptop Studio SSD Replacement: paso 4, imagen 1 de 1
    • Remove the seven screws securing the lower case with a T3 Torx screwdriver.
  5. Surface Laptop Studio SSD Replacement: paso 5, imagen 1 de 2 Surface Laptop Studio SSD Replacement: paso 5, imagen 2 de 2
    • Lift the lower case gently and set it above the device.
    • Take care not to strain the battery cable as you move the lower case.
  6. Surface Laptop Studio SSD Replacement, Surface Laptop Studio Battery Disconnection: paso 6, imagen 1 de 2 Surface Laptop Studio SSD Replacement, Surface Laptop Studio Battery Disconnection: paso 6, imagen 2 de 2
    • Disconnect the battery cable by lifting the pull tab until it "clicks."
  7. Surface Laptop Studio SSD Replacement, SSD: paso 7, imagen 1 de 1
    • After removing the devices battery, locate the SSD next to the mother board.
  8. Surface Laptop Studio SSD Replacement: paso 8, imagen 1 de 1
    • Remove the single 3 mm screw that secures the SSD.
  9. Surface Laptop Studio SSD Replacement: paso 9, imagen 1 de 1
    • Slide the SSD directly out of its socket.
Conclusión
2 personas más completaron esta guía.
4 comentarios
Is this strip tape or it metal? Is there replacements for it? I habe been trying to find it but I can only find tape as an alternative to this part.
Luis Ruiz - Contestar
I tried the SSD upgrade with two different WD products (1TB black and 1TB blue) and with both I had problems: Random blue screens and after some time, computed could not find the SSD anymore. Looks like it has something to do with drive consuming too much power but I am not sure. I am now back on original 256 GB SSD, since I can't find what is causing compatibility issues.
Pohistvo123 - Contestar
Can you fit a full sized ssd or only the short ones?
Omega_o7 - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 16
Ultimos 7 días: 94
Ultimos 30 días: 387
Todo El Tiempo: 6,706
