Saltar al contenido principal
Surface Laptop Studio Headphone Jack Replacement
Qué necesitas
  1. Surface Laptop Studio Headphone Jack Replacement, Lower Case: paso 1, imagen 1 de 1
    • Remove the rubber cosmetic strip along the outside edge of the back plate with tweezers.
  2. Surface Laptop Studio Headphone Jack Replacement: paso 2, imagen 1 de 2 Surface Laptop Studio Headphone Jack Replacement: paso 2, imagen 2 de 2
    • Remove the two rubber feet on the lower case with an opening tool.
  3. Surface Laptop Studio Headphone Jack Replacement: paso 3, imagen 1 de 1
    • Remove the two screws with a T3 Torx screwdriver.
  4. Surface Laptop Studio Headphone Jack Replacement: paso 4, imagen 1 de 1
    • Remove the seven screws securing the lower case with a T3 Torx screwdriver.
  5. Surface Laptop Studio Headphone Jack Replacement: paso 5, imagen 1 de 2 Surface Laptop Studio Headphone Jack Replacement: paso 5, imagen 2 de 2
    • Lift the lower case gently and set it above the device.
    • Take care not to strain the battery cable as you move the lower case.
  6. Surface Laptop Studio Headphone Jack Replacement, Surface Laptop Studio Battery Disconnection: paso 6, imagen 1 de 2 Surface Laptop Studio Headphone Jack Replacement, Surface Laptop Studio Battery Disconnection: paso 6, imagen 2 de 2
    • Disconnect the battery cable by lifting the pull tab until it "clicks."
  7. Surface Laptop Studio Headphone Jack Replacement, Headphone Jack: paso 7, imagen 1 de 3 Surface Laptop Studio Headphone Jack Replacement, Headphone Jack: paso 7, imagen 2 de 3 Surface Laptop Studio Headphone Jack Replacement, Headphone Jack: paso 7, imagen 3 de 3
    • Remove the left I/O bracket by unscrewing the the 3 M1109237 Screws with your T3 Torx screwdriver.
  8. Surface Laptop Studio Headphone Jack Replacement: paso 8, imagen 1 de 1
    • Remove the two M1168360 screws on the headphone jack with your T3 Torx screwdriver.
  9. Surface Laptop Studio Headphone Jack Replacement: paso 9, imagen 1 de 1
    • Flip up the headphone jack's ZIF connector locking flap.
    • Remove the ribbon cable from the port.
  10. Surface Laptop Studio Headphone Jack Replacement: paso 10, imagen 1 de 1
    • Lift the headphone jack up and out with your tweezers.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 6
Ultimos 30 días: 18
Todo El Tiempo: 86
