Saltar al contenido principal
Surface Laptop Studio Fan Replacement
Qué necesitas
  1. Surface Laptop Studio Fan Replacement, Lower Case: paso 1, imagen 1 de 1
    • Remove the rubber cosmetic strip along the outside edge of the back plate with tweezers.
  2. Surface Laptop Studio Fan Replacement: paso 2, imagen 1 de 2 Surface Laptop Studio Fan Replacement: paso 2, imagen 2 de 2
    • Remove the two rubber feet on the lower case with an opening tool.
  3. Surface Laptop Studio Fan Replacement: paso 3, imagen 1 de 1
    • Remove the two screws with a T3 Torx screwdriver.
  4. Surface Laptop Studio Fan Replacement: paso 4, imagen 1 de 1
    • Remove the seven screws securing the lower case with a T3 Torx screwdriver.
  5. Surface Laptop Studio Fan Replacement: paso 5, imagen 1 de 2 Surface Laptop Studio Fan Replacement: paso 5, imagen 2 de 2
    • Lift the lower case gently and set it above the device.
    • Take care not to strain the battery cable as you move the lower case.
  6. Surface Laptop Studio Fan Replacement, Surface Laptop Studio Battery Disconnection: paso 6, imagen 1 de 2 Surface Laptop Studio Fan Replacement, Surface Laptop Studio Battery Disconnection: paso 6, imagen 2 de 2
    • Disconnect the battery cable by lifting the pull tab until it "clicks."
  7. Surface Laptop Studio Fan Replacement, Fan: paso 7, imagen 1 de 2 Surface Laptop Studio Fan Replacement, Fan: paso 7, imagen 2 de 2
    • Remove the screws securing both of the fans with a T3 Torx screwdriver.
  8. Surface Laptop Studio Fan Replacement: paso 8, imagen 1 de 1
    • Flip up the ZIF locking flap on each socket.
    • Disconnect the ribbon cables attached to each fan.
  9. Surface Laptop Studio Fan Replacement: paso 9, imagen 1 de 2 Surface Laptop Studio Fan Replacement: paso 9, imagen 2 de 2
    • Lift the fans up and out.
Conclusión
Un comentario
Any idea where to buy the parts?
cameronjpu - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 8
Ultimos 7 días: 43
Ultimos 30 días: 134
Todo El Tiempo: 559
