Saltar al contenido principal
Repara tus cosas
Derecho a Reparar
Partes y herramientas
Introducción
If your tablet isn't maintaining a reasonable charge, you may need to replace your battery.
Partes
No se especificaron partes.
  1. Open the device using a plastic opening tool. Open the device using a plastic opening tool.
    • Open the device using a plastic opening tool.
  2. Kits para Nintendo Switch
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  3. Lift the battery  from the backing using a plastic opening tool.
    • Lift the battery from the backing using a plastic opening tool.
  4. Disconnect the attached wires from the battery by desoldering the connections.
    • Disconnect the attached wires from the battery by desoldering the connections.
Conclusión
Payton Butler
Miembro Desde 18/09/18
196 Reputación
2 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 8
Todo El Tiempo: 167
