Saltar al contenido principal
Supersonic Matrix SC-91MID Screen Replacement
Qué necesitas
  1. Supersonic Matrix SC-91MID Screen Replacement, Screen: paso 1, imagen 1 de 2 Supersonic Matrix SC-91MID Screen Replacement, Screen: paso 1, imagen 2 de 2
    • Place the plastic opening tool between the screen and the main component and pry open between the two. Once removed place the main component in a safe place and continue working on the screen section (highlighted in red).
    • Be aware of the wires when removing the display screen from the main component (highlighted in orange)
  2. Supersonic Matrix SC-91MID Screen Replacement: paso 2, imagen 1 de 3 Supersonic Matrix SC-91MID Screen Replacement: paso 2, imagen 2 de 3 Supersonic Matrix SC-91MID Screen Replacement: paso 2, imagen 3 de 3
    • Place the plastic opening tool between the metal screen plate and the black front casing.
    • There are small clips where the plastic opening tool can be placed to help pry the screen from the casing.
  3. Supersonic Matrix SC-91MID Screen Replacement: paso 3, imagen 1 de 3 Supersonic Matrix SC-91MID Screen Replacement: paso 3, imagen 2 de 3 Supersonic Matrix SC-91MID Screen Replacement: paso 3, imagen 3 de 3
    • Continue to slide the opening tool along the length of the casing until there is a clear separation between the screen and the cover (as shown in the third image).
  4. Supersonic Matrix SC-91MID Screen Replacement: paso 4, imagen 1 de 1
    • Once there is a clearing, carefully remove the screen from the black cover. You now have separated the screen from the tablet device and and are now ready to replace screen.
Conclusión
Una persona más ha completado esta guía.
Norikuni Nishikawa
Miembro Desde 03/31/18
139 Reputación
1 Guía escrita
Equipo
IUPUI, Team S1-G1, Wilson Spring 2018 Miembro de IUPUI, Team S1-G1, Wilson Spring 2018
IUPUI-WILSON-S18S1G1
5 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 7
Todo El Tiempo: 270
