Saltar al contenido principal
SuperSonic Matrix Mid SC-999 Rear Facing Camera Replacement
Qué necesitas
  1. SuperSonic Matrix Mid SC-999 Rear Facing Camera Replacement, Back Cover: paso 1, imagen 1 de 1
    • Wedge the plastic opening tool between the back cover of the device and the front panel.
    • You will hear a snapping sound as the cover is separated from the body of the device.
  2. SuperSonic Matrix Mid SC-999 Rear Facing Camera Replacement: paso 2, imagen 1 de 1
    • Slide the opening tool along the seam between the front panel and the back cover to un-clip the remaining connections around the device.
    • Again, you will hear a snapping sound as the cover is separated from the body of the device.
  3. SuperSonic Matrix Mid SC-999 Rear Facing Camera Replacement: paso 3, imagen 1 de 2 SuperSonic Matrix Mid SC-999 Rear Facing Camera Replacement: paso 3, imagen 2 de 2
    • Lift the back cover from the body of the device to expose the internal components.
  4. SuperSonic Matrix Mid SC-999 Rear Facing Camera Replacement, Battery: paso 4, imagen 1 de 3 SuperSonic Matrix Mid SC-999 Rear Facing Camera Replacement, Battery: paso 4, imagen 2 de 3 SuperSonic Matrix Mid SC-999 Rear Facing Camera Replacement, Battery: paso 4, imagen 3 de 3
    • Remove the Battery
    • The battery is secured to the back panel with tape and glue.
    • Peel back the tape around the battery and discard it.
    • Tear through the adhesive holding the battery by using the spudger tool.
  5. SuperSonic Matrix Mid SC-999 Rear Facing Camera Replacement: paso 5, imagen 1 de 3 SuperSonic Matrix Mid SC-999 Rear Facing Camera Replacement: paso 5, imagen 2 de 3 SuperSonic Matrix Mid SC-999 Rear Facing Camera Replacement: paso 5, imagen 3 de 3
    • Desolder the 2 Battery Wires
    • The Battery has two wires connected to the motherboard (one black and one red).
    • If you're unfamiliar with soldering or desoldering check out this guide.
    • Be sure to wear protective eye wear. The soldering iron will become extremely hot and a potential danger, so make sure you are aware of your surroundings.
  6. SuperSonic Matrix Mid SC-999 Rear Facing Camera Replacement, Rear Facing Camera: paso 6, imagen 1 de 2 SuperSonic Matrix Mid SC-999 Rear Facing Camera Replacement, Rear Facing Camera: paso 6, imagen 2 de 2
    • Remove the two Phillips #00 screws attaching the housing of the camera to the device.
  7. SuperSonic Matrix Mid SC-999 Rear Facing Camera Replacement: paso 7, imagen 1 de 1
    • With the screws removed you should easily be able to remove the camera unit.
  8. SuperSonic Matrix Mid SC-999 Rear Facing Camera Replacement: paso 8, imagen 1 de 2 SuperSonic Matrix Mid SC-999 Rear Facing Camera Replacement: paso 8, imagen 2 de 2
    • Follow the camera unit back to the motherboard.
    • Use the spudger tool to remove the camera.
Conclusión
Una persona más ha completado esta guía.
Harris Dagha
Miembro Desde 03/26/15
866 Reputación
7 Guías creadas
Equipo
Dr Shaverz boyz Miembro de Dr Shaverz boyz
Community
3 Miembros
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 8
Todo El Tiempo: 216
