Introducción
In this guide you will need to remove the back cover of the device and then locate the microphone. Using a soldering iron, you will remove the preexisting microphone and replace it.
Because this task requires the use of a soldering iron, prior experience with soldering/desoldering will be beneficial.
Qué necesitas
Wedge the plastic opening tool between the back cover of the device and the front panel.
You will hear a snapping sound as the cover is separated from the body of the device.
