Saltar al contenido principal
SuperSonic Matrix Mid SC-999 Microphone Replacement
Qué necesitas
  1. SuperSonic Matrix Mid SC-999 Microphone Replacement, Back Cover: paso 1, imagen 1 de 1
    • Wedge the plastic opening tool between the back cover of the device and the front panel.
    • You will hear a snapping sound as the cover is separated from the body of the device.
  2. SuperSonic Matrix Mid SC-999 Microphone Replacement: paso 2, imagen 1 de 1
    • Slide the opening tool along the seam between the front panel and the back cover to un-clip the remaining connections around the device.
    • Again, you will hear a snapping sound as the cover is separated from the body of the device.
  3. SuperSonic Matrix Mid SC-999 Microphone Replacement: paso 3, imagen 1 de 2 SuperSonic Matrix Mid SC-999 Microphone Replacement: paso 3, imagen 2 de 2
    • Lift the back cover from the body of the device to expose the internal components.
  4. SuperSonic Matrix Mid SC-999 Microphone Replacement, Microphone: paso 4, imagen 1 de 1
    • Remove the microphone from its compartment.
    • The microphone is located toward the bottom left corner of the device (assuming the speakers are located on the right side of you).
  5. SuperSonic Matrix Mid SC-999 Microphone Replacement: paso 5, imagen 1 de 2 SuperSonic Matrix Mid SC-999 Microphone Replacement: paso 5, imagen 2 de 2
    • Use the soldering iron to remove the wires connected to the microphone.
    • If you're unfamiliar with soldering or desoldering, check out this guide.
    • Be sure to wear protective eye wear. Also, keep in mind that the soldering iron will become extremely hot.
Conclusión
Harris Dagha
Miembro Desde 03/26/15
866 Reputación
7 Guías creadas
Equipo
Dr Shaverz boyz Miembro de Dr Shaverz boyz
Community
3 Miembros
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 11
Todo El Tiempo: 146
