Saltar al contenido principal
SuperSonic Matrix Mid SC-999 Battery Replacement
Qué necesitas
  1. SuperSonic Matrix Mid SC-999 Battery Replacement, Back Cover: paso 1, imagen 1 de 1
    • Wedge the plastic opening tool between the back cover of the device and the front panel.
    • You will hear a snapping sound as the cover is separated from the body of the device.
  2. SuperSonic Matrix Mid SC-999 Battery Replacement: paso 2, imagen 1 de 1
    • Slide the opening tool along the seam between the front panel and the back cover to un-clip the remaining connections around the device.
    • Again, you will hear a snapping sound as the cover is separated from the body of the device.
  3. SuperSonic Matrix Mid SC-999 Battery Replacement: paso 3, imagen 1 de 2 SuperSonic Matrix Mid SC-999 Battery Replacement: paso 3, imagen 2 de 2
    • Lift the back cover from the body of the device to expose the internal components.
  4. SuperSonic Matrix Mid SC-999 Battery Replacement, Battery: paso 4, imagen 1 de 3 SuperSonic Matrix Mid SC-999 Battery Replacement, Battery: paso 4, imagen 2 de 3 SuperSonic Matrix Mid SC-999 Battery Replacement, Battery: paso 4, imagen 3 de 3
    • Remove the Battery
    • The battery is secured to the back panel with tape and glue.
    • Peel back the tape around the battery and discard it.
    • Tear through the adhesive holding the battery by using the spudger tool.
  5. SuperSonic Matrix Mid SC-999 Battery Replacement: paso 5, imagen 1 de 3 SuperSonic Matrix Mid SC-999 Battery Replacement: paso 5, imagen 2 de 3 SuperSonic Matrix Mid SC-999 Battery Replacement: paso 5, imagen 3 de 3
    • Desolder the 2 Battery Wires
    • The Battery has two wires connected to the motherboard (one black and one red).
    • If you're unfamiliar with soldering or desoldering check out this guide.
    • Be sure to wear protective eye wear. The soldering iron will become extremely hot and a potential danger, so make sure you are aware of your surroundings.
Conclusión
2 personas más completaron esta guía.
Equipo
Baylor, Team 6-1, Shaver Spring 2015 Miembro de Baylor, Team 6-1, Shaver Spring 2015
BU-SHAVER-S15S6G1
4 Miembros
18 Guías creadas
Un comentario
Link to the soldering technique guide!
Josh Lewis - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 12
Todo El Tiempo: 2,336
