Saltar al contenido principal
SuperSonic Matrix Mid SC-999 Back Cover Replacement
Qué necesitas
  1. SuperSonic Matrix Mid SC-999 Back Cover Replacement, Back Cover: paso 1, imagen 1 de 1
    • Wedge the plastic opening tool between the back cover of the device and the front panel.
    • You will hear a snapping sound as the cover is separated from the body of the device.
  2. SuperSonic Matrix Mid SC-999 Back Cover Replacement: paso 2, imagen 1 de 1
    • Slide the opening tool along the seam between the front panel and the back cover to un-clip the remaining connections around the device.
    • Again, you will hear a snapping sound as the cover is separated from the body of the device.
  3. SuperSonic Matrix Mid SC-999 Back Cover Replacement: paso 3, imagen 1 de 2 SuperSonic Matrix Mid SC-999 Back Cover Replacement: paso 3, imagen 2 de 2
    • Lift the back cover from the body of the device to expose the internal components.
Conclusión
Una persona más ha completado esta guía.
Harris Dagha
Miembro Desde 03/26/15
866 Reputación
7 Guías creadas
Equipo
Dr Shaverz boyz Miembro de Dr Shaverz boyz
Community
3 Miembros
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 8
Todo El Tiempo: 425
