Introducción
When games have been in storage or used for years on end, they need to get a good dose of TLC. In extreme cases you need to crack them open to get everything. It can be tense opening up a loved game in the fear that you'll destroy it.
Alternatively, you can open up a game no one liked and make it into an innocuous enclosure for something else.
  1. On the bottom front corners of the cartridge you should see two screws using the 3.8mm "Gamebit" screwdriver bit. A 3.0U Spanner bit can also get them out. Once the screws are out, slide the front part of the plastic casing down to clear the tabs on the top of the case.
    • On the bottom front corners of the cartridge you should see two screws using the 3.8mm "Gamebit" screwdriver bit. A 3.0U Spanner bit can also get them out.
    • Once the screws are out, slide the front part of the plastic casing down to clear the tabs on the top of the case.
    • The two halves of the case should open easily.
  2. ¡Envío gratuito para todos los pedidos de más de USD100.00 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
    ¿Alguna vez arreglaste algo? Eso es genial.
    Comparte tu historia de reparación con #SoyUnGenio
    Todos somos Genios
  3. At this point the game board and pins are freely accessible.
    • At this point the game board and pins are freely accessible.
    • Here you can fully clean the pin set and inspect for damage to the circuit board.
    • Cleaning the pins is the easiest part; use a cotton swab and either a rich mixture isopropyl alcohol or Brasso. Other people swear by an eraser(the white kind), but it can lead to damage if you're not careful. Personally, Brasso works the best.
  4. NOTE: The top edges of the board are made asymmetrically so it can only go into the casing one way. Near the Blue Circles Games with battery backup (allowing for save games to be stored in SRAM) allow access to the battery at this point for replacement.  Most of the time the battery is a button cell: CR2032.
    • NOTE: The top edges of the board are made asymmetrically so it can only go into the casing one way. Near the Blue Circles
    • Games with battery backup (allowing for save games to be stored in SRAM) allow access to the battery at this point for replacement. Most of the time the battery is a button cell: CR2032.
      • The battery is soldered in. You will have to break it out and re-solder the new battery in.
Conclusión
To reassemble the cartridge, follow these instructions in reverse order.
15 personas más completaron esta guía.
BWest
Miembro Desde 02/09/10
2,801 Reputación
2 Guías creadas
Equipo
OPEN Miembro de OPEN
Community
75 Miembros
15 Guías creadas
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 35
Últimos 30 Días: 142
Todo El Tiempo: 23,432
