Saltar al contenido principal
Sunbeam Snow Cone Maker Dasher Replacement
Qué necesitas
  1. Sunbeam Snow Cone Maker Dasher Replacement, Dasher: paso 1, imagen 1 de 1
    • Push the button on the back to release the lid. (Missing on this example device.)
    • In the photo on the device page it is red.
  2. Sunbeam Snow Cone Maker Dasher Replacement: paso 2, imagen 1 de 2 Sunbeam Snow Cone Maker Dasher Replacement: paso 2, imagen 2 de 2
    • Unscrew the dasher by holding it in the middle and turning clockwise.
    • You will have to spin it quite a bit.
    • Remove the dasher.
    • Alternately, you can continue to step 3 to further disassemble the dasher components.
  3. Sunbeam Snow Cone Maker Dasher Replacement: paso 3, imagen 1 de 2 Sunbeam Snow Cone Maker Dasher Replacement: paso 3, imagen 2 de 2
    • To take the dasher apart, remove the three 5.5 mm Phillips #00 screws embedded in the plastic. **The 3rd screw is behind the hand in the picture
    • Carefully pull the two pieces apart.
    • When you've finished taking apart the dasher, you should have two parts that are shown in the second picture in this step.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 3
Ultimos 30 días: 24
Todo El Tiempo: 820
