Saltar al contenido principal
Sunbeam Mini Pie Maker FPSBPMM980 Disassembly
Qué necesitas
  1. Sunbeam Mini Pie Maker FPSBPMM980 Disassembly, Sunbeam Mini Pie Maker FPSBPMM980 Disassembly: paso 1, imagen 1 de 3 Sunbeam Mini Pie Maker FPSBPMM980 Disassembly, Sunbeam Mini Pie Maker FPSBPMM980 Disassembly: paso 1, imagen 2 de 3 Sunbeam Mini Pie Maker FPSBPMM980 Disassembly, Sunbeam Mini Pie Maker FPSBPMM980 Disassembly: paso 1, imagen 3 de 3
    • Open the pie maker.
    • Remove four 4 mm screws holding the crescent-shaped black plastic plate in place with a Phillips #1 screwdriver.
    • Remove the black crescent-shaped plastic plate.
  2. Sunbeam Mini Pie Maker FPSBPMM980 Disassembly: paso 2, imagen 1 de 2 Sunbeam Mini Pie Maker FPSBPMM980 Disassembly: paso 2, imagen 2 de 2
    • Repeat the previous step to remove the upper black crescent-shaped plastic plate from the upper half of the unit.
    • The pie maker's symmetrical construction may cause confusion—in this image the pie maker is resting on its upper half.
  3. Sunbeam Mini Pie Maker FPSBPMM980 Disassembly: paso 3, imagen 1 de 1
    • Remove the four 4 mm screws located directly on either side of the hinges with a Phillips #1 screwdriver.
    • Successfully removed screws will allow for the separation of the pan component from the outer plastic shell.
  4. Sunbeam Mini Pie Maker FPSBPMM980 Disassembly: paso 4, imagen 1 de 3 Sunbeam Mini Pie Maker FPSBPMM980 Disassembly: paso 4, imagen 2 de 3 Sunbeam Mini Pie Maker FPSBPMM980 Disassembly: paso 4, imagen 3 de 3
    • Remove the final two 4 mm screws from the circular black plastic bottom base plate with a Phillips #1 screwdriver.
    • Remove the black plastic base.
  5. Sunbeam Mini Pie Maker FPSBPMM980 Disassembly: paso 5, imagen 1 de 3 Sunbeam Mini Pie Maker FPSBPMM980 Disassembly: paso 5, imagen 2 de 3 Sunbeam Mini Pie Maker FPSBPMM980 Disassembly: paso 5, imagen 3 de 3
    • Disconnect the two red and green incandescent lights from their fixtures by popping them out of their red plastic cradles.
  6. Sunbeam Mini Pie Maker FPSBPMM980 Disassembly: paso 6, imagen 1 de 3 Sunbeam Mini Pie Maker FPSBPMM980 Disassembly: paso 6, imagen 2 de 3 Sunbeam Mini Pie Maker FPSBPMM980 Disassembly: paso 6, imagen 3 de 3
    • Examine successfully disassembled Sunbeam Mini Pie Maker FPSBPMM980.
    • If desired, remove insulatory coated paper cut outs to more easily access heating coils.
  7. Sunbeam Mini Pie Maker FPSBPMM980 Disassembly: paso 7, imagen 1 de 1
    • Examine electronics schematic.
    • The Sunbeam Pie Maker utilizes four heating coils to bring miniature pies to an internal temperature of 175+ F. The pies are placed in the appliance after pre-heating, and are cooked for approximately 10 minutes, or until golden brown. The machine begins pre-heating upon being plugged in, signifying it is receiving power with the red light.
Conclusión
To reassemble your device, follow these instructions in reverse order. Happy fixing!
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 6
Todo El Tiempo: 129
