Saltar al contenido principal
Sunbeam FPSBPMM980 Disassembly
Qué necesitas
  1. Sunbeam FPSBPMM980 Disassembly, Sunbeam FPSBPMM980 Disassembly: paso 1, imagen 1 de 1
    • Open up the device.
    • Using the Phillips #2 screwdriver, remove the two 12 mm screws and the two 15 mm screws from the top handle.
  2. Sunbeam FPSBPMM980 Disassembly: paso 2, imagen 1 de 1
    • Remove the lock and spring from the device.
  3. Sunbeam FPSBPMM980 Disassembly: paso 3, imagen 1 de 1
    • Remove the handle from the device.
  4. Sunbeam FPSBPMM980 Disassembly: paso 4, imagen 1 de 2 Sunbeam FPSBPMM980 Disassembly: paso 4, imagen 2 de 2
    • Using the Phillips #2 screwdriver, remove the two 12 mm screws that attach the top half to the hinges.
    • Disconnect the top half of the pie mold from the rest of the casing.
  5. Sunbeam FPSBPMM980 Disassembly: paso 5, imagen 1 de 2 Sunbeam FPSBPMM980 Disassembly: paso 5, imagen 2 de 2
    • On the back of the upper pan, use the Phillips #2 screwdriver to remove the two 12 mm screws that attach the top pan to the hinge.
    • Using the same screwdriver, remove the two 6 mm screws that attach the thermostat to the back of the top pie mold.
  6. Sunbeam FPSBPMM980 Disassembly: paso 6, imagen 1 de 2 Sunbeam FPSBPMM980 Disassembly: paso 6, imagen 2 de 2
    • Using the Phillips #2 screwdriver, remove the two 12 mm screws and the two 15 mm screws from the bottom handle.
    • Remove the bottom handle from the device.
    • Using the Phillips #2 screwdriver, remove the two 12 mm screws that attach the lower pan to the hinge.
  7. Sunbeam FPSBPMM980 Disassembly: paso 7, imagen 1 de 1
  8. Sunbeam FPSBPMM980 Disassembly: paso 8, imagen 1 de 3 Sunbeam FPSBPMM980 Disassembly: paso 8, imagen 2 de 3 Sunbeam FPSBPMM980 Disassembly: paso 8, imagen 3 de 3
    • Close the device and turn it over.
    • Using the Phillips #2 screwdriver, remove the two 12 mm screws from the bottom lid and slide it out.
  9. Sunbeam FPSBPMM980 Disassembly: paso 9, imagen 1 de 1
    • All Done!
    • Operation Guide: Insert the plug of the pie maker into a 120V socket. The Power (red) light will turn on. Wait until the plates heat up to the necessary temperature and the “Bake ready!” light (green) will turn on.
    • As soon as the green light turns on, you can use it. After finishing cooking, just unplug the pie maker and leave it open to cool down.
    • There are only lights that can turn on/off. The red light turns on when you plug the pie maker and the green light turns on when the thermostat detects the necessary temperature on plates.
    • Temperature is not regulated on this device, but is sensed to indicate when the device is ready for baking.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 11
Todo El Tiempo: 136
