Saltar al contenido principal
Summer 3D Lite Convenience Stroller Front Wheel Replacement
Qué necesitas
  1. Summer 3D Lite Convenience Stroller Front Wheel Replacement, Front Wheel: paso 1, imagen 1 de 2 Summer 3D Lite Convenience Stroller Front Wheel Replacement, Front Wheel: paso 1, imagen 2 de 2
    • Locate the black plastic tabs on the front wheel. There should be two, opposite sides from each other.
  2. Summer 3D Lite Convenience Stroller Front Wheel Replacement: paso 2, imagen 1 de 2 Summer 3D Lite Convenience Stroller Front Wheel Replacement: paso 2, imagen 2 de 2
    • Firmly press both tabs inwards, and use your other hand to pull the wheel off
Conclusión
7 personas más completaron esta guía.
Equipo
Cal Poly, Team 11-5, Forte Fall 2015 Miembro de Cal Poly, Team 11-5, Forte Fall 2015
CPSU-FORTE-F15S11G5
4 Miembros
3 Guías creadas
15 comentarios
How can i order the front wheels
Amalia Ontiveros - Contestar
Hi, you can contact the Summer Infant Consumer Relations Team by calling 800-268-6237, Monday-Thursday, 8:00am-6:00pm EST and Friday 8am-3pm EST.
Stroller Guy -
I think there should be a video tutorial for this product. thank you!!
Lisa D. Richards - Contestar
Yes i think there should be a video
yummy mummy fantom XXX -
The Front wheel is less bending in the axis, how to make straight by hand
Samson Wong - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 8
Ultimos 7 días: 78
Ultimos 30 días: 307
Todo El Tiempo: 55,259
