Saltar al contenido principal
Summer 3D Lite Convenience Stroller Back Wheel Replacement
  1. Summer 3D Lite Convenience Stroller Back Wheel Replacement, Back Wheel: paso 1, imagen 1 de 2 Summer 3D Lite Convenience Stroller Back Wheel Replacement, Back Wheel: paso 1, imagen 2 de 2
    • Set the stroller up so the front wheel is on the ground with the metal push tab up.
  2. Summer 3D Lite Convenience Stroller Back Wheel Replacement: paso 2, imagen 1 de 2 Summer 3D Lite Convenience Stroller Back Wheel Replacement: paso 2, imagen 2 de 2
    • Push the tab in with your finger enough so the plastic can slip out above the tab.
  3. Summer 3D Lite Convenience Stroller Back Wheel Replacement: paso 3, imagen 1 de 1
    • OPTIONAL: If the tab is being difficult, use a key to push the tab in further in order to slip plastic out of place.
  4. Summer 3D Lite Convenience Stroller Back Wheel Replacement: paso 4, imagen 1 de 1
    • The wheel should slide right off the pole once the tab is pushed out of place. It is now possible to make repairs or replace the wheel completely.
Conclusión
4 personas más completaron esta guía.
Nick Taylor
Miembro Desde 09/28/15
188 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 11-5, Forte Fall 2015 Miembro de Cal Poly, Team 11-5, Forte Fall 2015
CPSU-FORTE-F15S11G5
4 Miembros
3 Guías creadas
2 comentarios
Gd, have a question . Were can u buy spare parts for this type of stroller?
pieterroos - Contestar
Can you tell me if you have a rear wheel that will fit a summer 3D go convenience stroller all black?
charles nelms - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 15
Ultimos 30 días: 69
Todo El Tiempo: 10,860
