Saltar al contenido principal
Subaru Legacy 2009 Key Fob Battery Replacement
Qué necesitas
  1. Subaru Legacy 2009 Key Fob Battery Replacement, Key Fob Battery: paso 1, imagen 1 de 2 Subaru Legacy 2009 Key Fob Battery Replacement, Key Fob Battery: paso 1, imagen 2 de 2
    • Use a Phillips #00 screwdriver to remove a 5.0 mm screw from the base of the key fob.
  2. Subaru Legacy 2009 Key Fob Battery Replacement: paso 2, imagen 1 de 2 Subaru Legacy 2009 Key Fob Battery Replacement: paso 2, imagen 2 de 2
    • Place the flat end of a spudger into the gap between the key blank (metal part) and the case.
    • Gently pry upward to separate the housing.
  3. Subaru Legacy 2009 Key Fob Battery Replacement: paso 3, imagen 1 de 1
    • Once the case comes apart, turn the key upside down, and the keyless fob should easily come out.
  4. Subaru Legacy 2009 Key Fob Battery Replacement: paso 4, imagen 1 de 3 Subaru Legacy 2009 Key Fob Battery Replacement: paso 4, imagen 2 de 3 Subaru Legacy 2009 Key Fob Battery Replacement: paso 4, imagen 3 de 3
    • Use a spudger or your fingernails to pry open the four clips securing the keyless fob.
    • Ensure that you pinch the fob on the side, not the top, during the opening to avoid accidentally re-securing the clips.
  5. Subaru Legacy 2009 Key Fob Battery Replacement: paso 5, imagen 1 de 3 Subaru Legacy 2009 Key Fob Battery Replacement: paso 5, imagen 2 de 3 Subaru Legacy 2009 Key Fob Battery Replacement: paso 5, imagen 3 de 3
    • Gently slide a spudger beneath the battery to lift it from the case.
    • Replace it with a new CR1620 3V lithium coin battery.
    • Reassemble the key fob.
Conclusión
Brandon Lu
Miembro Desde 01/09/24
121 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 19
Todo El Tiempo: 150
