Saltar al contenido principal
Stuck Shutter Fix Replacement
  1. Stuck Shutter Fix  Replacement, Shutter: paso 1, imagen 1 de 1
    • Put the camera in any mode other than Auto, and turn off the flash.
    • Turn off the LCD screen and press the DISP or DISPLAY button.
  2. Stuck Shutter Fix  Replacement, Adjust the Camera Setting: paso 2, imagen 1 de 1
    • For many canon cameras this will be shutter priority mode, that will give you the longest exposure time without flash.
  3. Stuck Shutter Fix  Replacement, Open/Close the Battery Door: paso 3, imagen 1 de 1
    • After a few seconds open the battery door then close it again. This will momentarily interrupt power during the exposure time.
    • Repeat the procedure until the shutter becomes unstuck.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 34
Ultimos 30 días: 120
Todo El Tiempo: 6,698
