Saltar al contenido principal
Sticky Key Saxophone Fix
Qué necesitas
  1. Sticky Key Saxophone Fix, Sticky Key Saxophone Fix: paso 1, imagen 1 de 1
    • Locate sticking key.
  2. Sticky Key Saxophone Fix: paso 2, imagen 1 de 1
    • Screws are located down from key.
  3. Sticky Key Saxophone Fix: paso 3, imagen 1 de 1
    • Loosen screw slowly and carefully, so that screw isn't lost.
  4. Sticky Key Saxophone Fix: paso 4, imagen 1 de 1
    • Test key and note free movement.
  5. Sticky Key Saxophone Fix: paso 5, imagen 1 de 1
    • Put saxophone completely together and test out key.
    • If key still sticks repeat previous steps.
Conclusión
Loosen screw until key moves freely or as desired. Once as desired, you are then ready to play the instrument and test out key!
AlysonStrange
Miembro Desde 05/30/17
101 Reputación
1 Guía escrita
Un comentario
An Issue I have with a sticky key on my Alto Saxophpone. I found a remedy on ifixit.com, a hack recommended for fixing pretty much anything! Try it out!!
kwiggins01 - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 27
Todo El Tiempo: 1,790
